Mine still started with the wrong TCM files loaded, and IIRC, the shift pad also blinked. it just would not go into gear. On mine, the wrong TCM came from an RV, and I assume an interlock was put into place to ensure slide ins or jacks were stowed.
To get it reprogrammed with 6th gear, your best bet may be to contact Charlie Ball on Facebook. Check the link I posted for more info on him. If the dealer reprograms the TCM, they won't be able to unlock 6th.
-----------------So I talked with Charlie Ball and got a sweetheart of a deal.
It seems that since I got the TCM from a like unit (engine/trans) I probably don't need to get it re-flashed but calibrated instead.
The donor bus probably had interlocks for wheelchair or e-door and I only need to get the TCM re-calibrated and turn off those interlock features which are causing the TCM to go into "Shift inhibit" mode.
The sweet deal...only $50 bucks, plus shipping both ways.
God I hope it's this simple!
Ok, sO i think I got this figured out.
GEN3 (3 connectors to TCM) use troubleshooting manual TS2973EN
Pages 190-192 will identify each wire and what the function of that wire is.
Page 352 has the circuit diagram for the SHIFT- INHIBIT- BRAKE PEDAL CIRCUIT.
TCU with the SHIFT INHIBIT circuit enabled must have wire 155 permanently connected to wire 161 if this function (shift Inhibit) is not being used.
The "V" (Gray) connector, v-11, green wire #155, General purpose input #1 gets connected to...
V31, Yellow wire, Digital return.
The corresponding pins are Pin/terminal 11 and Pin/Terminal 31 on the connector itself at the TCM.
Skoolie scholars, please take a look and tell me if this makes sense...
If this works, easy fix/work around for others changing TCMs who have the shift inhibit enabled!
TS2973EN-6.7MB, can't upload...
https://www.trucktransdiag.com/downloads/wtec3.pdf
Disregard post #146, I got is wrong!
The way I'm reading this, you want an open circuit between the two pins to disable the shift inhibit (doors closed, ready to drive). When shift inhibit is active, your shift indicator goes dark. From what I've read so far your shift pad isn't going dark, it's flashing 6 right?
I wonder if this⤴ would be an option for owners who've cut wires and have interlock troubles. $50 is a cheap interlock fix.
Took a 40 mile test drive and all went well!
70 MPH @ 1900 RPM!
WOO HOO!
