General AC Wiring (or, how I would do it)
There are a couple ways to wire the bus, and by this I mean:
Do I put the wires in the chase up by the ceiling;
Do I put them along the floor behind the cabinets;
Do I put them in conduit under the bus?
I'm probably going to do a combination of the three. Most of the main wiring I will run under the floor, going through grey PVC for the main runs from the panel to the runs that will be broken down into the individual areas.
The PVC will be firmly supported, preventing any sag or vibration from operation of the bus which would fatigue wires and cause breakage or shorts.
Any wire connections will have wires twisted together with pliers, wire nuts firmly screwed on, then further secured with colored electrical tapes.
The electrical tape colors will also be an indicator of what the circuit is for; I will be color-coding the wires so I know what goes where for future repairs and additions.
Then I will make up a wiring diagram for future reference.
At that point I will branch up/out to any outlets or switched lights, running under any convenient cabinets or up the wall in a chase to protect the wires.
If any wires proceed up to the ceiling for lighting, cooling etc., those will be protected by ceiling panels that can either have space to run future wires, or a chase installed, or the panel will be removable for repairs, or a combination of any of these.
RV/Vehicle wiring MUST be stranded, NOT solid wire!
15 amp outlets and lighting will be served with 12 gauge/with ground 'SO'-style cable, also known as Extension Cords!
Yep, per my Licensed Electrician friend who gave me the staright poop on this...I will also be tinning the ends of the wires with ROSIN-CORE solder so it makes for better connections.
DO NOT USE ACID-CORE SOLDER, IT WILL EVENTUALLY DISSOLVE THE WIRING.
20 amp outlets, lights and circuits will be served with 10 gauge SO cords.
Sure can't beat the prices, especially if I get them as seconds or on sale at the discount stores.
If larger cuircuits are needed, I will find out what are the appropriate gauges of wire to be used for those applications, and use the appropriate stranded wire.
A circuit panel will be connected to the 'shorepower' cable with a disconnect so that the panel either takes power from the shore supply, OR the genny, but NOT both at the same time...don't want any polarity or backfeeding problems that will turn my wiring to smoke!
If I use GFCI breakers right at the panel, they will protect any circuit directly down-line of that breaker...this will also make installations easier, as GFCI outlets are bulky and somtimes hard to fit all the wires in the box.
Which reminds me:
All electrical boxes, whether for switches, outlets, etc. are stamped with their volume in cubic inches. These are limits on how much stuff you can SAFELY load any box with connections and devices. PAY ATTENTION TO THESE SPECS!!!
The ground for the main panel will ALSO be grounded directly to the bus chassis and bodywork; I want to eliminate any possible chance of electrocution just by leaning on the bus.
The ground and neutral wires from the panel will be kept separate at all times.
I will also keep in the 'shore power cable storage box' a circuit tester to let me know that the shore power I plug into is grounded and connected correctly. These testers plug into a standard 15- or 20-amp outlet, and let you know by indicator lights what's up. IF plugging into a 30-amp outlet, use an adapter to check it, too.
All cables that exit the conduit and run free under panels, etc. will be supported no less than 18 inches apart, to prevent vibration fracturing of the wires. All wires that enter outlet and switch boxes will be supported within 6 inches of the box for strain relief, and to reduce wire flex and breakage.
If the wire is to be in an exposed but dry (interior) space, I will use armored cable with the appropriate gauge cable and fittings. Don't forget the bushings on the end of the cable armor to prevent chafing of the wires on the metal.
If the wires are to be in an exposed EXTERIOR space, I will use waterproof armored cable AND fittings.
If the wire passes through any openings, I wall make sure that there will be appropriate grommets or other measures to prevent chafing of the insulation.
I will be using commercial grade outlets and switches, as they are heavier duty and more reliable in the long run. I think this saves money and time, too.
I will think twice, no, THREE times before I use any USED electrical equipment, as I have no idea if the equipment had been previously installed correctly or subjected to unusual loads that may have done unseen damage.
Circuits that will be protected by the GFCI breakers will include, but are not limited to, the kitchen area, the bath area, and any exterior outlets.
These will be 20-amp breakers.
I will NOT use any "push-connect" wiring on the back of outlets and switches, as they have a tendency to arc if loose or vibrated. I will ONLY use the correct screw connections, and will ground all circuits.
I will leave a minimum of 6 inches of wire in each box, as I will need adequate lengths to ensure I have the connections properly made.
I will also check each circuit I have finished, using an appropriate meter.
That's it for now, more to come (eventually)
