Ryan Grimm
Re: How To: Bus Electrical Systems - AC
Found this in another section of Skoolie.net:
viewtopic.php?f=8&t=13540
shutterbug3 said:Quick question for the electrical gurues: I am working on installing a fusable disconnect into a conversion and I have used 10/3 for running between a 6 circuit panel; I only have 8 total outlets, 1 will be powered full time for a fridge/freezor and another will be a laptop charger/cell phone charger outlet(from an inverter) on the road and the others will only be used once plugged in on shore power. With only 4 of the 8 outlets running more than 50% of the time even when on shore power, do I need 50 amps and is 10/3 gauge OK(is only running approx. 2 ft. between panel and disconnect) or will 30A be sufficient. A small pottery wheel, a task light and maybe a small electric fan being my other loads once plugged in. I know 10/3 is only rated at 30 A, so will I be in danger of using 10/3 or do I need to upgrade.
claydbal said:tell me what is wrong with this idea. i plan on totoally isolating my 120v ac from the rest of the body/chassis. a simple plug to the power pole or generator leading through the breaker box and on to dedicated wall plugs. no chassis gound, no body ground.
claydbal said:if no wire can touch the metal, and can only be plugged into either the power pole or the generator, then how will this not work? how will it not be safe?
quote from http://peavey.com/support/technotes/safety/shockhazard.cfmOne of the problems with appliances and equipment which have a "floating metal case" is that a shock hazard exists if the case comes into contact with the hot wire. This so called "fault condition" may happen in many ways with some of the more common causes being a "pinched" line cord, failure of installation systems, or movement of components due to shock or vibration which will cause the "hot wire" terminal to touch the case. Naturally, if for any reason the case does become "live," then a person touching it may be shocked if he is grounded. If this "hot chassis" is connected to another chassis or instrument by a typical shielded cord, then that chassis or instrument will become hot also. The entire purpose of the present three wire system is to provide a separate ground path which will effectively eliminate any possibility of shock.
claydbal said:tell me what is wrong with this idea. i plan on totoally isolating my 120v ac from the rest of the body/chassis. a simple plug to the power pole or generator leading through the breaker box and on to dedicated wall plugs. no chassis gound, no body ground. if no wire can touch the metal, and can only be plugged into either the power pole or the generator, then how will this not work? how will it not be safe?
i plan an entirely seperate system for 12v dc through inverter for solar power and another system for 12v dc only for lights/fans/other.
pick it apart and chastise me!
claydbal said:is anything wrong with my plan?
claydbal said:they were all wood and the only way to get a shock was to actually touch the wire itself.
missingTexas said:What determines which outlets are 15amp versus 20 amp?
Some of my appliances (Fridge, AC units) say they should be wired with 18 gauge. I just figured I would run everything 18gauge but there are so many options.. red black twisted, red black separate wires, just black, just red .. omg my head is spinning
I was thinking I would do all of my outlets in the special CFCI plug just to be safe, but all of this talk of 15 versus 20 amp has me a tad confused.
So while I do not have 240V in my bus (since they are not both connected to anything) I still have 2 hots coming in and could for some reason actually put in 240 for say a 12 person hot tube and sauna room
