Floor & Decor
Hello All
I have a 2003 Thomas (Freightliner) Bus, I am in the process of converting.
Does anyone have any secrets regarding ripping out the floor?
What is the floor made of anyway? Seems like its as hard as a rock and also wondering if its worth ripping out.
Any input is huge..
Thank you all.
The bottom is steel, then plywood is screwed down. Glue is applied over plywood and screwheads. Rubber in top, with some steel trim & edging.
I used a razor to cut the rubber to remove only the strips over the screwheads. Then razored the glue from each screwhead (weirdo here)
I removed every single screw. Didn't pry or cut any if the plywood. All whole pieces & I have a can of stainless screws. I only treated & primered the rusty areas of the floor for rust. The rest was cleaned and painted only.
The central Florida bus above was 12y/o at the time of these photos. Similar to a TX or GA bus, not as good as AZ or CA, while several salted states are known to be worse.
The plywood seems to trap moisture onto the metal, meanwhile the workers perforate the floors as they screw down the wood. Note the rust patterns in the photo above. The self tapping screws also create metal shavings which are intentionally left in between to help speed up the oxidation. Mine smelled like p!ss underneath. Maybe just kids being kids. Idk
Not all buses have the plywood layer, but most do. Use a good magnet
. You ought to be able to tell if there is 1 full inch of plywood & rubber OR just rubber & glue, which is about an 1/8" thick.
The buses without plywood, just rubber glued down, seem to fair much better. I like to speculate: maybe it's the lack of screw holes & ergo shavings, which make the difference but also, simply gluing the rubber directly to the steel, keeps the metal dry. No wick gaps.
You haven't told us the region you live nor the location where your bus was in service. Service life makes a huge difference on your decision to investigate further.
throughly clean the floors, treat any rust with Ospho & a wirewheel, then paint with rusty metal primer and/or implement paint, depending on the rust damage.
At this point, most builders seal up the floor. Before you install any insulation or new flooring, solve the water intrusion, leaks, condensation, including wet/dirty workers" shoes/boots.
The larger sheets of plywood can be repurposed for a mower shed or kids playhouse. I made a chicken coop.
