Hello,
We recently purchased a mini bus, a super bantam. We have begun the tear apart and have cleared out the seats, the walls and ceiling panels and all the old gross wet insulation. Rust has been wire wheeled and treated. Leaks have been identified and once it stops raining will be addressed.
We started on the floor today and have run into a problem, the rear heater. We like having the heater and want to keep it in is original location. The problem is that we need to remove and replace the flooring under it. We have tried to move it but it won't move more than an inch up off the floor. There are 2 hoses, one on each end of the heater running down into the floor under the heater and they appear to be copper. Our plan was to simply lift the heater up enough to get the flooring out and slide a new section under it. It is sitting g directly over a gas tank so we can't access it from underneath the bus easily. Help! What do we have to do to get the flooring out?
