Booyah45828
I now see you're in AZ, no rural kings there. Tractor supply has group 31's for 134.99, I imagine they're might be cheaper elsewhere, so call around.
If money is a problem. Charge and test each of those 8d batteries individually.
Odds are, one is likely good enough to do the job solo if it's in decent shape.
If you have a group of batteries, and one battery with a bad cell, that battery will bring down and deplete the other batteries in the group.
Charging might take a day or 3 to do, but all your out is a little bit of time if it doesn't work out. Take the charger from the pic, flip it to the 10 amp option, and leave it on there for a while. After a day, remove the charger and put a voltmeter on it, if it's above 12, keep charging it for another day or 3, below 12 and the battery is junk.
That's if the bus can continue sitting where it's at for the week. If it's gotta move, new batteries are your only option.
Went to start the bus today because I will be moving it to another place. However, it won't start.
I heard a loud clicking sound that got weaker after a few seconds. The gauges move around crazily and some lights blink.
When I was redoing the rear brake lights I used a voltage tester and it all worked fine. Now I can't even get the blinkers to work.
NOTE:
The bus has been sitting for a few months. However, I have been using a battery charger and now an engine warmer.
A while back I removed some wiring and redid the rear lights. However, the bus did start after that and I even drove it. In fact, I drove it with the rear light wiring rigged temporarily with some tape. It started and ran fine more than once.
Here is a link to a short video on youtube showing what happens when I turn on the ignition key:
https://youtu.be/DJ0QxKJotko
Thanks!
I purchased a Group 31 battery at Nappa; 1,000 CCA for about $170.
Bus started right up!
Thank you all for your help!
When I needed new batteries for my MCI, the best price I found was from Batteries +, I purchased 2 Duracell 8D, that was about 2 years ago, zero issues since then.
Batteries + still looks like the best Price around.
They also give an extra 10% if purchased online, then picked up in the store.
https://www.batteriesplus.com/productdetails/sli8db
Peter
In the future- if you're anywhere near a Rural King they sell G31's for $79 each. Glad you got it started!![]()
