Kandall
1993 international bluebird
Mechanical DTA466
Preface:
We removed the rear heaters, keeping the front drivers side heater, but we forgot to shut the coolant valve next to the engine, although we did manage to shut the valve next to the driver-side front heater. Forgetting to shut the valve next to the engine could be the issue here but were not sure how to fix it if that is actually the case. The coolant line is currently looped on the left rear side of the driver seat.
We drained a little over 5 gallons of green coolant from the heaters. Since then we've added about 2 gallons of orielys brand green coolant to the radiator, the radiator appears to be full now.
The current issue:
Now when we turn the ignition without trying to actually start the bus, the "oil/water" light comes on.
Then when we turn the ignition all the way to try to start the bus, the "water in fuel" light comes on and nothing happens.
Mechanical DTA466
Preface:
The current issue:
