Replaced my ECM yesterday due to ongoing issues that are fully documented in the thread here, and the issue was fixed / bus started fine, no comm fail message. However upon starting, I now have a fault code SPN 84 / FMI 2 (Cummins code is 241). Description for this code is: Wheel-Based Vehicle Speed - Data Erratic, Intermittent, or Incorrect…seems to relate to the vehicle speed sensor on the rear of the transmission. I have yet to drive the bus to see what the impact is, but looks like this could impact max engine speed, cruise control, gear down protection and road speed governor.
As a background, when I got the replacement ECM (refurbished from GoECM) they loaded a calibration directly from Cummins that is the same as my previous - I think….I say this because my previous ECM was not readable, so I have no idea what the changeable parameters were in that program. (I am however pretty sure about the calibration code as it is the same as what was stamped in my old original ECM.) One of the adjustable parameters is the Vehicle Speed Sensor Type….from the printout I have of the programming, this is set to “Data Link - Tachograph”…. I think this may not be the actual sensor type, and that is why I get the active fault code at key-on - i.e., because the ECM is looking for a different particular type of sensor than what is actually installed on the transmission.
Cummins documentation on this fault code mentions that the speed sensor is an OEM installed component (so Blue Bird - whom I’ve already called and they can’t find any documentation), and that there are various types, including: magnetic pickup, data link, digital and tachograph…I am leaning towards an ECM setting as being the likely culprit here, as that is the first step in troubleshooting…
So here’s the Q: anyone out there have a clue as to what a 2010 BB with Cummins 6.7 ISB and Allison 2500 PTS might have? @cadillackid maybe?
