cxzcxzcxz12345
- Joined
- Feb 22, 2023
- Posts
- 12
Hey folks,
I have a question about my skoolie’s towing capability. My bus is a 30-ft mid-size bus with a manual transmission and a T444E engine. I’m planning to tow a half-ton F150, but I’m concerned about whether the engine can handle such a heavy load.
The GVWR of my bus is 25,500 lbs. I haven’t weighed it yet since it’s still under construction, but the fully loaded weight of the F150 is around 5,500 lbs. Do you think my bus can safely tow this weight?
I’m particularly worried because I had a bad experience driving the bus uphill in the past. I had to shift down to 1st gear to climb the hill. At the time, I was new to driving a manual transmission, so it’s possible the bus could have handled the climb in 2nd gear, but I shifted to 1st out of caution.
My questions are:
1. Do you think my bus can safely tow this weight?
2. What is the typical weight of a mid size skoolie, I have no idea how heavy is 25,500 lbs and should I worry overweight my bus?
3. Is anyone here driving a manual T444E like mine? Would you feel confident towing a 5,000+ lb load with it?
My questions are:
