redbaron415
I'm currently considering doing a roof raise, however I'd like to avoid taking out the windows to do so.
I see that everyone does their roof raises by taking out the windows, cutting the metal studs in between each window in half and then jacking up the roof. The problem with this method, in my opinion (and this is with zero understanding of structural integrity of the bus), is that it requires you to fill in the windows with new sheet metal once you're done raising it. Part of the attractiveness of converting a school bus (rather then a sprinter) is the windows in my opinion. While they suck for insulation purposes, I love the light they let in, and it sounds expensive as **** to have to cut out new windows slots from the new sheet metal and install either pre-fab or retro fit windows. So, in a perfect world, I'd ideally be able to do a roof raise AND keep the original windows.
Here's what I'm thinking: Can I simply remove the rivets that hold the roof to the body of the bus (or cut it off entirely, if that is not possible) and add 1-2ft of new sheet metal above the windows? In this scenario, I would extend the metal studs that run from the floor, up to the windows, so that they go as high as the new sheet metal would stand. That way it has something secure to weld onto. From there, I would rivet the roof back onto the new siding.
Does any of that sound feasible? I'm shooting from the hip here. It's completely theoretical idea, with zero understanding for engineering and whether or not this would be structurally sound.
Sincerely appreciate any thoughts on this.
