Grasswaiting
- Joined
- Oct 2, 2018
- Posts
- 40
I have a 2007 Thomas C2 5 window and I’m 6’5” so I have 1” total of clearance to the metal ceiling ribs standing barefoot on the bare metal floor. I want to maintain standing height at all costs. The entire bus is sprayed with closed cell foam level with the ribs and underneath the floor for maximum insulation, given my situation. The ceiling will be fully shaded by solar panels.
Is it reasonable to do the following with my 1” of clearance height or would you guys have a better idea (other than a roof raise)?
1) 1/2 inch T&G ceiling : Use 1/4 inch foam thermal break tape on the ceiling ribs, then countersink flat trim screws directly into the ribs in 1/4 inch cedar T&G and wood putty the holes (1 per board per rib)
2) 1/2 inch waterproof cork floor : Use 1/4 inch XPS foam underlay thermal break, then float the 1/4 inch waterproof cork flooring over top (the underlay does not void the warranty without a subfloor).
Happy holidays all!
Happy holidays all!
