DeMac
🚍Bus Lunatic🤪
We've framed enough of the ceiling to install the overhead Electrical rough-in. The permanent wire structure is being used for our temporary lighting, while we build. I'll document our process in this thread.
I'll briefly cover the ceiling framing we chose. A simple process repeated often at skoolie.net, neither unique or complex.
Overhead Electrical Rough-in includes any overhead raceways & wiring.
Usually lighting, switchlegs, rooftop A/Cs, exaust fans, ceiling recepticals, smoke & CO2 detectors, sign or flood lights. Overhead often includes low voltage & communications, which I'll complete separately.
The high voltage wire methods used on Freddy D are commercial grade. Steel armored cable, steel boxes, steel fittings, steel supports.
