Center Aisle or Side Aisle floor design? Need Pros and Cons
ReconcilingRoamer
Feb 1, 2019
39
Upstate South Carolina
Okay Skoolies...
Getting a skoolie layout together in 3D and can't seem to decide if a center aisle design works better than a side aisle design or even a "maze" style floor design.
Want to hear pros and cons for all you guys out there living the dream!
Nothing But The Best,
RR
Biggest issue is height. Most people can't stand upright if the aisle is down one side of the bus. That's why center aisle is predominant. Stand in a bus and see for your self. Every person is different, and some busses have taller ceilings.
If you're short you can put it anywhere you like.
I prefer down the center. No wheel wells to climb over too.
I'm quite the shorty at a staggering 5' 1" lol. I'm trying to be as innovative and thoughtful as possible with water tank storage and being able to "hide" solar/power/water/AC components within the layout.
Thank you for the advice! :)
:thumb::thumb::thumb:
Thank you. I am a towering 5' 1" lol. So I am hoping once I walk through a conversion it will just click.
Do you have any opinion on if the symmterical center aisle offers more storage space or "concealment" abilities for utility components?
If you ever have anyone else in the bus they may appreciate the headroom.
I'm just outside of the upstate in Rock Hill. I've gotten my seats out and put the flooring in, everything else is stock (ceiling, walls, etc).
If you're not too far in the mountains (don't want to test the 545 with mountains just yet) I can ride up and you can see what works for you in terms of aisle location. I've got 72" headroom (the absolute minimum), and at 5' 10" I've set my max aisle location to just under the stock lighting running down the bus, about 1 1/2 feet from the wall. Any closer and I start to hit my head on things.
If you're 5' 1" you won't have any problem with a wall aisle on a low height bus.
While it may be annoying for taller friends/family, wall aisles allow for a much larger rooms (if you decide to go that route) and if not, then much larger open spaces that are not interrupted by thoroughfares.
One thing I'd suggest in the floorplan stage - take a look at trains, specifically passenger trains. They have minimal space as well, and some I've seen have gotten creative with their layouts. Especially the bedrooms and lounges as they have a moderate amount of "reconfiguration" - ie the bed can turn into a chair and table.
Another suggesting is making floorplans out the wazoo. Always nice to have multiple options/references, since Murphy will always make sure something doesn't fit "just" right. Right now I'm likely going to implement a floorplan I had for a TC2000 transit for my dognose.
Dorian Proctor on Sketchup Warehouse has some amazing and accurate sketchup models that I used. You have to scale them down, but once that is done they are nearly 100% accurate in everything - windows, wheel wells, doors, etc.
I started out center, and haven't changed anything....
But I am considering side aisle, because I like the way the kitchen & bathroom finishes out in the designs I've seen. And the rear bathroom wall would make better mounting flat screen.
examples:
You are a gem! Thank you! This was some great info! I am about 2 1/2 hrs from Rock Hill. I'll have to get with you and throw around some ideas! Do you have Instagram or Facebook?
examples:
YYEESSSS!!! The Center aisles are visually pleasing and feel like a good use of space but the bottom picture you posted is what I have been drooling over for weeks now. I love the Mayes Team bus! Hopefully at the GA Tiny House festival I will be able to walk through a few different conversions and get a good idea! Thank you for sharing!
you're welcome.
Don't forget your holding tanks and fuel tank (2 fuel tanks in my case)will dictate where your plumbing will run... ie: right side of bus or left
Hard to cross over drive shaft & frame:oops:
when you visit the Tiny House festival... be sure to ask about their tank placements:thumb:
We did center isle. The kitchen just feels right that way as you can stand in one spot and just turn around to get to everything.
Our water tank is on the right side opposite of the sink and bathroom. grey and black are under the bathroom. I routed out the threshold between the kitchen and back bedroom to allow the water line(1/2" pex) to cross over.
I love the Mayes Team bus and a bunch of others that have the L-shaped kitchen! However, whenever I do my floor plan in Sketchup, I just can't fit everything in with the L-shape that I can with the center aisle. It just makes sense for me to have the center aisle. I think for the longer buses it definitely works. I have just under 29' from the driver's seat and engine to work with after insulating the walls.
Millicent is still center aisle, but I am considering changing over to side aisle so I can have a queen bed on the ground floor.
I cannot have a queen bed across the back, because of the cargo compartment and tail-gate. And I am not giving up the door between the living area and the cargo compartment.
Of course, the ceiling is already two feet higher than originally.
So, RR... that is my minor contribution to this brainstorming session -- think of the largest item you need room for.
Thanks for asking, I have this very same question. I'm drawn the one side design, but was wondering if that causes any issues with weight distribution?
(I have a 30' FE transit style Thomas, that will recieve an 18-21" roof raise)
I prefer the side aisle do the better utilization of the open space you create in a bus in a bus interior design that you get with a side aisle.
It only takes a couple of times to remind you of the lower ceiling height along the walls and then you always remember!
I'm in a similar situation to you. I'm planning a roof raise on mine (I'm 5'11" and my roof is 6'2", and I need better insulation) but kinda like the side-isle idea as it keeps my bathroom design contained and means only one fan needed instead of two. But as you get farther back, unless you have a flat-front bus, you will need to deal with a rear wheel well.
