kidharris
The floor of my bus is attached to the chassis rails with these clip/bracket things:
They're a slightly-bent piece of formed sheet metal that bolts into the bottom of the cross-member and clips the body to the top flanges of the chassis rails. Does anybody know what these are actually called and where I could find eight or so of them online?
I basically need to clip my new frame to the chassis in the same manner. I've though of a few ways to improvise something to do this, but I'd rather attach something meant for this.
I'm thinking a straight piece of 1/4 inch, same width and length as the originals, drill a hole in same spot, phosphate and paint, put some washers the same thickness as the frame metal (or slightly thinner) under the strap/clip and bolt it down. Done. You could weld a piece the same thickness as the frame under the strap, then drill the hole, if you wanted something prettier or stronger. This is just s clamp.
