I'm not opposed to solar, but it's so expensive for the little amount of power you actualy get....lets do the math.
As an example, we'l ltry to use your 45 watt solar panel kit to run your dorm fridge.
45 watts @ 12 volts is 3.75 amps....@ 120 volts that 0.375 amps.
Assume you got full sun for 12 hours (unlikely here in michigan) then you would end up with:
45watts per hour x 12 hours = 540 watt/hours per day (in a nearly perfect world)
540 watts/12 volts = 45 amp/hours
factor in at least a 10% loss into your batteries
45-5 = 40 amp hours available
then run that through your inverter....loose another 10% or so
36 amp/hour of available 12 volt current to through your inverter would leave you with 3.6 amps (@ 120 volt) of draw for one hour.
What you end up with, is the ability to run your dorm fridge for about 1 hour per day off of the 45 watt solar panel kit.
After spending 200 bucks plus shipping for that........spending the $857 for the honda eu doesn't sound so bad, does it?
