freedomforwoodfam
- Joined
- Jul 20, 2024
- Posts
- 1
Help! we have a 2001 bluebird with a cummins engine and allison trans. I took the heaters out and i guess I didn't do it right. The bus now won't start and the check trans light is on. I drew out what I did you can see it here
. If that link doesn't work see it here: https://www.mosaicifs.com/hidden.html
as far wiring goes, there were 2 clusters of colored wires (1 for each heater) that connected to the panel at the front side of the bus. there was also a gray cable that went from that front panel to the back where it had a ground (connected to the wall of the bus) and continued on to the heat pump under the bus (I think). that part had the brand name "bergstrom" which google said is a bus heater. anyway, thoughts would be helpful!
