Thanks
Yes, you would think finding answers with the MTO would have been simple. It's been multiple visits and calls to many offices, and I am left with going back to the first number now after the office I visited couldn't get the answers either. I see this will be a bit of work to dig up.
Let's talk about those 4 things: There are 6 criteria out of which at least 4 must be met for it to qualify:
1). Cooking facilities
The clamp on bbq from the boat won't work...I assume. What are the requirements, that it needs to be bolted into the vehicle?
2). Refrigerator/ice box
I understand my cooler that plugs into the lighter won't be sufficient...?
3). Self contained toilet
This one I do think will work with the boat version moved to the bus, however it has to be in a vented space, correct?
4). Heating/air conditioning system
This is the one that boggles us all a bit...the bus comes with heat and AC. Is that sufficient?
5). Portable water facilities
Would it work to have a water cooler tank installed with a spigot into a sink?
6). Independant electrical supply.
We have a generator for the bus...what needs to be altered or configured to meet this requirement?
Clearly I need a set of regulations to follow in order to determine which of these will be best...?
