Cleaned out the garage
Rivetboy
Jul 29, 2017
939
Huntington Beach CA.
This is all that was replaced in the Cummins 5.9. That little silver fitting is the check valve that keeps the fuel from going back to the tank and losing your prime.
That one blew freely both ways. About $50 bucks at NAPA and located by the fuel water seperator on a 91 TC2000
Put the exhaust in complete with all hangars and reinstalled the driveshaft.
Progress!
Good to see you changed the damper. A lot of folks overlook that because they don't understand how it works and it's importance.
Looks like you were busy! How much left to replace?
Engine is done with remanufactured turbo and air compressor rebuilt at 545 and a thermostat controlled aux fan cooler for the trans all in. Starting the new dash build .Have all of the instruments wire breakers switches splices heat shrink terminal strips new processed instrument panel and a plan!
Mine is in a holding pattern for the moment. Need to get a ton of "other stuff" arranged before I can move ahead with it. I do have about 95% of the gauge wiring in place though. Does that count as progress?
