Close off the gap at the bottom of a window frame to stop (some) leaks?
try to stop the water before it gets to the inside lip as if it stays in the wall it will not only rust but the freezing water will deform your window/frame. that will lead to worse leaks. try to stop the water on the outside not the inside
I am thinking about welding the gaps shut to fix the window seal leaks. This is my third round trying to get my windows properly sealed and I am on the edge of madness. I have sanded and cleaned the window frames on both previous attempts and used 3M Dyntron Auto Seam Sealer but the windows are still leaking through the bottom corners of the windows and through the bus seams in some areas.
I want to know if anyone has actually gone through with welding the gaps on each of the windows instead. I intend to use flex seal and butyl tape as well but it seems to me that welding these gasps shut will be the solution to the leaks. If anyone has gone the welding route please let me know the outcome. PLEASE HELP!
I don't believe seam sealer, or butyl tape have any reason to be anywhere near your windows. Auto glass shops use polyurethane sealant to set car windshields. Polyurethane can be purchased from any big box store for no more than the price of any other caulking. A friend of mine owns an auto glass shop and has re sealed many buses for the school district and has completed 4 skoolie's in the past for himself so I'll trust his advice. I've just completed removal and re seal on half my bus windows and first hose test shows no leaks.
Your windows are aluminum, no? It would be a tough order to weld them to the steel ribs.
A number of my windows leaked (and are still leaking) in this manner. The source (in my case) is the seam between the bottom part of the window's outer frame and the two side parts. These pieces are only pressed together, so if this gap opens up even a tiny bit, it will allow in substantial water (when I had my windows out and put a hose on this part, water sprayed through into what would be the inside of my bus when mounted). The fix is to seal the outside of the window sill, in the hard-to-access corners that the moveable pane slides down into. I used my pinky to spread the seam sealer here, but it has not adhered very well and I need to redo my sills with a small craft brush.
Yup, more and more I'm thinking a BIG bead of spooge on the outside of the glass and the aluminum will be the way to go. Not even bother with removing the windows --just seal the outside with a clear spooge.
One day the inside of my bus will be pretty -- the outside will still be scrapping tree branches...
Do you by chance recall the brand of polyurethane you used for yours? I just got done cleaning all the seam sealers off the frame and windows and I am getting ready to put the windows back and seal them again. I appreciate the feedback.
There you go!
Right out of the paint department at Home Depot.
Polyurethane has great flexibility, adhesion and is paintable.
I just pulled and prepped my next six windows this afternoon, the reason I do six at a time is its not too overwhelming like having them all out at one time and you should be able to set 5-6 windows on one tube of sealant. The tubes do not last very long once they've been opened.
Good luck with your work
Cheers
I am personally not a welder, I would have to get a professional to do the work. I am asking because it seems to make so much sense to weld those gaps on the bottom corners with an additional piece of metal on each side as a permanent solution to any leaks. Then follow with treating the corners to avoid rust after the weld, put the windows back, seal the outside of the windows with something that works and move on to the next project. I just haven't found anyone that has done it that way and I'm wondering if there would be any drawbacks besides having to pay a welder.
There you go!
Cheers
Thank you 👏
I also am not a welder but I do own several machines and am capable with them. even with that its not something I would consider doing right now. That's a ton of extra work (24 windows) I'm comfortable with the prep I'm doing now to reseal them, hope that doesn't change a year from now. Can't imagine what a welder would charge.
Any downside? Other than cost? I don't think so.
Got it, I having a pro looking at it this week for a quote. I'm sure the cost will make me stop asking the question lol. I appreciate the feedback though. Either way the leaks shall be fixed, I have to get on the road soon!
The red lines here show where you want to have a watertight seal. If I interpret you correctly, the green area is what you want to weld something over. But the only way water could get to here is if the water is getting past the red line seal (or if water is going through the window unit). If you have water getting past your window to the inside like this, you're still going to have a problem whether or not you close up that gap.
Window sealing
Good silicone don't crumble.
If I installed that window with silicone, and proper surface prep, you would never get the window out of the opening ever again.
As with any caulking, surface prep is everything.
Nat
I agree! Prep is everything! You have to use a wire brush a scraper and acetone to get all the old sealant off. Of course you'll have to remove the windows completely to clean and seal it properly. I've used Henry's 289 with some success. $5 at Homedepot
In auto glass the inter frame is only to set the window in, it is not designed to stop water. The sealant/seal around the exterior of the window is designed to stop water from getting in.
If you wield the back corners and water gets that far it will just sit and rust out the corner.
My bus windows had the same leaks from the bottom corners, the 30yr old calking was wore out. I spent about 4-5 hours with a 5&1 putty knife and acetone cleaning and prepping the outside window frames, then applied about 3-4 tubes of calking. No leaks since.
