Clouse House
Clouse House Skoolie
Hello everyone! Just getting a thread started for my new to me bus and build. Hoping to not only keep track of my build here but to also put up future plans for everyone and anyone's input.
I'm currently in my late 20's almost 30's with a fiancée and two young boys. I've worked in the warehouse industry for practically my entire adult life and I've always been a "why pay someone when I can do it" type person. About two months before my first son was due our landlord at the time told us he had intentions to sell the house and that we needed to find somewhere else to live. In a panic we bought a "fixer upper" that needed quite a lot of fixing. Over the past four years I have remodeled the entre house, ran plumbing for the bathrooms, built a deck, ran electric out to the deck and installed a breaker box in the shed, and so much more. Then just two months ago at the peak of the 2022 housing market inflation we sold that house. I'm hoping that with my experience from remodeling the house and with the nest egg leftover from paying off the mortgage, I'll be able to build a nice Skoolie for my family to call home. We do plan on living in it full time and travelling for the first 2-3 years, then potentially settling down back home or in a new location if we happen to fall in love with it. At that point we would use the skoolie as a foundation for a homestead or who knows, maybe we'll just keep travelling.
We found a 2008 IC PB30500 only about four hours from us that we purchased about a month ago. It is a 40ft flat nose rear engine school bus with a Maxxforce DT engine and an Allison 3000PTS transmission. At the time of purchase it was still registered to the school district as an active duty bus and had just passed the school board inspection. The PO had simply wanted to try out a different career and was on the fence about selling the bus. We helped him make that decision. After traveling home and taking the bus up and down over 6 miles at 6% grade I discovered that it had a few "minor" problems. A pin hole coolant leak on a 4in long coolant hose leading to the oil cooler, just big enough to make a mess at high temps and under load but small enough to not leak at idle. I also discovered a power steering leak, not sure yet if it's the hose or the fitting but it is also a slow leak.
We already have plans on modifications to the bus that are unskoolie related such as an external oil cooler, trans cooler, possibly aftermarket EGR's and plumbing in a second radiator. Since we plan on towing a vehicle behind us and have family both in the north east and out west we would be driving a lot in the desert heat and in the mountains. And I just want to make sure that the engine and transmission are well taken care of for those journeys.
I have spent close to six months planning out our build. I have a floor plan, a solar plan, a water tank diagram, an electrical closet diagram and more to share with everyone and get opinions on. I'm really looking forward to getting feedback from everyone on my family's first journey together.
I'm hoping right now as I type this at work that 6in is enough to make them level with the metal floor, if not then hopefully to atleast get them below the new floor level after adding the 2.5in of insulation/subfloor.
I cut the power and ground wires going to the heater and then stoop it up with the hoses at the top. This raised it higher than the coolant level in the engine. The hoses were held on with hose clamps that I could fit a 3/8in socket onto. I undid the hose clamps before pulling the hoses off of the heater. A trick for stuck hoses is to grab the hose on the fitting and twist it back and forth, this will most of the time unstick it. As I was pulling the hoses off the heater I could hear the sound of air entering the hose, I assume that was the coolant feeding back into the engine to try and level out. I put in the 3/4inch pipe plug and retightened the hose clamp on it. I did that again for the other hose and that was taken care of mess free. I picked the heater up and tipped it over slowly into a coolant drain pan until no more fluid came out and then carried it off of the bus.
