I put up my battery box and started working on the water tank mounts the past couple weeks. The battery box is a
Buyers 18"x24"x36" underbody box. It's interior measurements are large enough to fit four of the
48V 100AH Batteries that I plan on using for this build. It should have plenty of room with 6" both above and in front of the batteries.
I overdid the support for the battery box quite a bit, I made it the same way that I plan on making the water tank mounts. So the battery box was like my test run. I learned:
1) leave some wiggle room. 1/8" on all sides to aid in installation, a shim can always be added after
2) find a better way to lift it up and hold it while securing it
Here's some photos:
Design is copied from
Chuck Cassidy's Water Tank Installation Video
It is essentially a two piece angle iron cage. The top section is like a four-legged table. Angle iron all around with flat bar legs, with some square tubing on top of the whole thing for mounting. The bottom section is a rectangle made of angle iron,(one side is just flat bar because of the way the box opens) with mounting holes that allow it to be bolted to the legs of the top section.
The frame just barely fit under the side skirt of the bus when I was testing the fit but it did manage to fit. That's good news as my water tanks are actually shorter than the battery box so they won't be an issue at all.
I'm installing the battery box where the rear AC condenser was, so the hole isn't an exact fit and I'll need to add some metal in if I want it to look pretty.
I used six M8 rivnuts in the ribs underneath the bus to mount the upper section of the frame. Capable of holding 29,100lbs, I feel like they should handle the 600lbs of frame, box, and batteries just fine.
Here is the frame very loosely put in with some spring clamps to hold it up while I line up the holes to bolt it in place. You can see more of the frame and the square tubing on top.
Holes were cut in the bottom of the square tubing to allow for the socket to fit through the tubing and bolt it in place.
And this it what it looks like looking up into the hole after bolting it in place.
My boys were a great help retrieving tools for me that were just out of reach and they wanted to see if they could fit inside. Yes they can.
