How would one go about getting an ohm meter on the glow plugs? We are uncertain as to whether or not ours are working. Apparently the light going on doesn't actually have anything to do with it, nor does the period of time the light is one relate well to the period of time the glow plugs are heating, if indeed they are heating. We have one of those laser temperature gauges - cheap from Harbor Freight- and pointed it at the engine while cycling thru the glow plug light ten times and did not notice any temperature difference. Whether or not we should be able to notice any from the outside as opposed to the inside is not clear to me. It seems possible to me that the diesel inside was being heated but not enough to heat up the engine block itself noticeably? Glow plugs themselves aren't expensive but apparently changing them out is a PITA because they are under some cover?
My bus also runs fine but does NOT like to start (although supposedly it started right up before I bought it?) It spent the night with the engine block heater plugged into the house, so it will be interesting to see if it starts today whenever my son gets up. We FINALLY got Mobi home at about 2am- on day three of a 360 mile trip!!! Good Lord that was more difficult than I'd hoped, but definitely a learning experience. We now have a new battery, a new fuel filter and we cleaned out the fuel filter bowl including flushing the drain line, and added fuel conditioner for the cold.
I did have one nasty surprise- the expensive Good Sam roadside assistance I bought is NOT in fact valid for incomplete bus conversions. Basically, if we didn't have water tanks they weren't going to help?!?! WTF?! My son was talking to them so I need to verify today. I want my money back if they aren't going to help me until my bus is fully converted. I do NOT understand why, if they will tow a heavier bus or help with a problem on the road on a heavier bus, they don't want to help with one that weighs less for the same price. I bought the service three weeks before I called the RV assistance line hoping for tips to avoid a roadside call. They were not helpful as the assistance was basically, well, should we send out a mobile unit? Why have a separate line for that? Has anyone else run into this with Good Sam?
