Tigerman67
What is the reason for changing the title from a bus to a motor home? Does your insurance drop? Cheaper tags?
If your vehicle is designed to carry more than 15 passengers, or is more than 26k lbs GVWR, you need a class B CDL license regardless of what you plan to use it for. If you also have airbrakes, you would need the Airbrakes endorsement. If you bus still has the word 'School' on it (reguardless of weight or # of passengers), you are suppose to have a slightly different passenger endorsement for school bus passengers.
An RV is a specific carve out in the federal law, and you can drive one with a regular license (some states have a 'heavy' non-commercial license that might be required, but CO doesn't not appear to have that).
https://www.colorado.gov/pacific/dmv/cdl-general-information
If you look on that page, under which vehicles don't require the CDL, RVs, military and certain farm vehicles and a few others.
Depending on your point of view, you probably don't have to stop for weigh stations as an RV, but do if you qualify as a Commercial vehicle. If you are at a weigh station, if they choose to bother you, I think as a commercial vehicle/driver, there is alot of things they can get you for since you were suppose to do your pretrip inspection before starting out and zero things are suppose to be wrong with your vehicle.
If you have to have a CDL, then you have to have a log book, and you can't exceed DOT hours while operating a commercial vehicles. Electronic log books are now being required as well, but not sure which vehicles have to have them.
I think tags are cheaper, as there is an assumption you are using the road less than a commercial vehicle.
Insurance CAN be cheaper, but insuring a converted Bus as an RV will give you another set of hurtles to clear in order for the insurance company to take you seriously as an RV. Not impossible, just difficult if you are just starting out. For the state, the bar is very low for the conversion, and they take your word for it. Your insurance company will likely want pictures, and those minimum accommodations I made for the state would be unlikely to fly with any insurance company.
