I recently bought a Chevy G30 short bus (12 ft body) that was partially converted. I pretty much tore everything out and am glad that I did. I found leaks from bad caulk as well as mistakes the previous guy made. I have sealed all those up. I also tore out the entire floor and the sidewalls which allowed me to find leaks I never would have found otherwise. I pressure washed the floor, applied a rusty metal primer, and then coated it with tractor paint. I plan to glue down EPS foam insulation and top with plywood for the floors. I plan to put XPS in the walls.
The bus is a lot drier now and I thought the leaks were gone. I am seeing some water in the sidewalls and cannot tell where it is coming from. I sealed the windows so figured it might be from the roof. Is this a common issue. There are rivited seams but no skylights or escape hatches. It is a 1996 G30 Chevy chassis with a Blue Bird 12ft body as measured from behind the driver seat if that means anything.
I am new to this so where should I be looking? I am about ready to start reconstructing the inside the way I like but want to take care of this fundamental problem first.
