condensation
I had to look up where goldbar was. I thought you'd be over on the beach.
I'm dealing with the same 5.9 you are. It does seem small for this size of a vehicle. I'm pretty sure this wood I've used weighs less than the steel panels I took out, but I didn't keep track. I did weigh this bus after removing the interior panels and it seemed to be about 1,300 lbs less. I just wanted a durable interior. I don't carry a lot of weight otherwise, like an interior.
Hey, keep everything. As soon as you throw something out, you end up needing it.
No, the perforated panels wouldn't be good for window replacement. They would be good for a window cover. Any other uses are good too. You'll never get cheaper sheet metal to play with.
Well convinced ceiling has to go as the only cure for PNW condensation. Will buy an air chisel and I counted and only 400 rivets on my ceiling and one row of screws. I have been nudged screaming and kicking all the way to doing the bus job right, not my intention when I bought the bus as I thought redoing the floor would be enough. Hoping a combination of tongue and groove on the sides and fiberglass/plastic sheets in center will help with headspace, though when final flooring is put in not sure anyone over 5'8" will ever be able to walk in my bus, luckily I am shorter than that.
I would have been satisfied with the OEM inside panels too, but the water issues are actually kind of impressive in a negative way this time of year.
Another one converted. :angel:
Your air chisel will probably have its tip formed in a V shape so that it comes to a point in the middle of its thickness. That shape doesn't work well for shearing rivets. Re-grind it so it's flat on one side and tapered on the other (the same profile as a wood chisel).
Use a small punch to drive the mandrel back into the middle of the rivet before trying to shear the head. This significantly reduces the amount of metal you have to shear. Some of the rivets might turn out to be aluminum with a steel mandrel; these will shear like butter when the mandrels are pushed back first.
Thanks FamilyWagon - will regrind air chisel or see if they sell one like that to start with. I will try punching them and see what luck I have. On my lower walls the horizontal rivets were easy to drill out the vertical ones had the steel center and I ended up grinding an x and bashing away at them. I fear the roof rivets are of the tougher type.
Why do you not add 1" insulation to the top of the roof,, insulation and barrier in one, easy to do, cheap, no head room loss. no strength loss
Later J
Just punch out the mandrels and shear off the rivet with the chisel.
You'll kick yourself for drilling and grinding!
You're doing the right thing!:thumb:
