Tyania
First... FLOORS... I have:
Removed seats and old floors.
Removed loose rust.
Grinded and wire brushed rust spots.
Had a body shop guy weld all holes and patch rusted through areas at the corners of one wheel well. Everything grinded flush.
Removed silicon from edges and corners.
Treated the entire floor with a "phosphatizing" solution, then washed floor.
Treated entire floor with rust converter.
Painted with a quality primer.
was able to get rust converter under the driver seat plate with a sponge on a stick but the primer is thick. Any ideas?
http://www.skoolie.net/forums/members/17901-albums1378-picture17899.html
still to do...
Recaulk the corners and edges.
Install flooring.
Am I missing anything?
Is the primer enough or do I need paint on top.
Removed loose rust.
still to do...
Install flooring.
