trentet
I just read an interesting article on biodiesel related to it's use as a lubricating agent in injectors and pumps. The gist of the article is that as the EPA restricts the amount of sulfer and other aromatics in diesel the lubricating qualities of diesel go down proportionally. I had been warned of this previously and it was suggested that a quart of motor oil be added to my 40 gal tank with each fill up to preserve the injector and pumps. with the addition of minimum 2% biodiesel you retain enough lubricant qualities to preserve your expensive injectors and pumps. here's the link to the article, thought you might find it interesting.
http://www.biodiesel.org/pdf_files/fuelfactsheets/Lubricity.PDF
The website also lists places you can buy biodiesel from the pump but I don't live anywhere close. Bakersfield CA is the nearest metro area to me and it was built on oil and rednecks so not expecting to see any real soon
