I recently completely rebuilt my entire cooling system due to perennial overheating problems that were getting worse. I'm guessing my bus's cooling system is not much different than a BB transit bus's - I have the info for BB pusher school bus's cooling systems, and mine is broadly similar. I had a new radiator core made, powder-coated both radiator tanks and the surge tank, had a new 9-blade fan made by Multi-Wing, had a new Webster YC hydraulic fan motor made by QCC, replaced my Webster KB hydraulic/PS pump, replaced the Danfoss solenoid directional control valve, moved the hydraulic cooler to a different location, added a separate second transmission cooler, added a hydraulic filter, replaced both thermostats, replaced a lot of hoses, added a hydraulic pressure relief valve and two pressure gauges, and did a lot of other associated work as well. Now the bus doesn't completely overheat at the sight of a slight hill, but the temperature still isn't quite where I would like it to be. I'm now toying with the idea of adding a second radiator, either on the right side or at the back, but I need to know what heat rejection I could expect from it before I start a project like that - if I turn on my heaters I see an immediate drop in temperature, and they are 150,000 BTU/hour total. My engine requires about 12,000 BTU/minute (720,000 BTU/hour!) heat rejection through the coolant, but a Cummins 8.3 will be less than that.
The reason I changed out essentially everything was because I don't want to have to deal with this ever again! The fan motor was slightly leaking internally, the pump probably also was the same (it has visible wear to its gear lobes), the heavy old 6-blade metal fan made more noise than moved air, and the radiator had some cold spots and the beginnings of corrosion. After I got everything back together I realized that the fan was still not turning fast enough even at full speed, and it turned out to be the $35 hydraulic control valve that was leaking internally - just changing that alone made a big difference.
Hydraulic fan systems are not intrinsically complicated, and they can work very well. However, age and wear take their toll, and small amounts of degradation here and there will add up to a significant reduction in overall cooling ability. If one specific item is not working right you can replace it alone, but in my experience everything just wears out at the same rate, meaning that you may need to just bite the bullet and change out everything. Yes, it's a lot of work, but I'll never have to redo what I've now done, ever.
Here's Blue Bird's information on their hydraulic fan drives, I assume for school buses. I expect their transit buses and Wanderlodges use something similar:
http://www.centralstatesbus.com/2003_BBAA/a3pdfs/a3hydfan.pdf If you have any other questions about hydraulic fan systems, feel free to ask me - I'm not an expert, but after working on mine I think I understand the basics!
I notice that the new bendy-bus transit buses here have a bank of nine electric pusher fans, and those fans are at full speed every time the bus comes to a stop, but after a minute or so the fans slow down a lot. What's adequate for a transit bus that stops every minute for a rest may not be suitable for a bus traveling at sustained speed. I can't imagine that those transit buses would do too well climbing Baker Grade on I-15 northbound when it's 115 degrees outside! There's good reason that long-distance buses use hydraulic or belt-driven radiator fans - it takes up to 40 HP to power a fan, and no electric motor(s) come close to equaling that. The subject of using electric fans for primary cooling is discussed every few years on the BCM forum, and the general consensus of thought there is that electric fans simply will
not work on a RE bus that's driven continuously in all weather conditions and over any grades. It would have been a lot cheaper and easier for Blue Bird or Crown or Gillig to slap on a few electric fans and call it a day, but they didn't do so simply because it would not be sufficient. In other words, fix what you have, and don't second-guess the original engineers!
PS - if your bus uses a Danfoss 7WA110 solenoid directional control valve to vary fan speed, I can tell you where the last two in this country are for only $35 each (less than a tenth of their original SRP).
