Corbi
I’m making headway on my short-bus conversion, a 1999 GMC Savana cutaway 5 window wheelchair school-bus. I Purchased it from a Hudson Valley school district at auction with 145 K miles on it. Corbi has a 6.5 GM/DT diesel engine that so far, runs well.
The main challenges to date were removing the rubber and plywood floor-covering. Since the bus had a 3 wheelchair capacity, I needed to remove three sets of Q-Straint attachments, bolted to the underneath. One set was above the gas tank. The other two had access from below, but were firmly rusted in. Another challenge is the physical limitation of where I’m parked: It’s a rented spot in a social service agency parking lot—so the building managers rent out spots by the month that are not needed by the agency. So, I had to contain debris in the bus until I ran out of space and had enough to bring it to the privately-run building materials recyclers. I finally dropped off the last load of debris, and started on the sub-flooring lastI used this site primarily for ideas about building the floor. I took in account my parking situation, and decided to use 1/2 inch xps board under 1/2 in of plywood. There was one large hole and a few lesser ones caused by rust—I have a corrugated galvanized metal deck. I decided to use a rust inhibitor primer to prevent further decay. This week, I’m going to tape the seams of the foam boards, and get ready for the plywood install. Its feels good to reach this stage of the conversion.
