Covering the crack between wall and ceiling
witchywoman
Jan 6, 2020
165
Stanardsville, Virginia
What did you guys use to cover the crack between the inner walls and the ceiling?
I’m painting the outside of my bathroom and there is 1/4 inch gap between the wall and ceiling. I can’t find any trim that is bendable.
I've seen a bus owner use rope glued over the gap you're looking to cover.
Don't know if that goes with your interior motif, but it might be a lower cost option if you think it will work?
Good luck, and post pics of your "solution"...
1/4 round comes in many widths and is bendable. The rope idea works well also as there are any types and size of rope you can use. Bendable and make 90* turns around corners, glued or tacked with brads.
