02 International 3000IC T444E 7.3
Crank no start!
I have no oil pressure from HPOP although i do have oil pressure on the dash (40-50psi). I have checked all fuses and relays, all in working order with good connection. I have also checked all pig tails confirming proper voltage and continuity. I know my LPOP is working because it filled up the reservoir after it was drained for new HPOP install (also telling me my pickup tube isn't broke cracked or blocked). Reservoir doesn't leak down so relief valve/ball is in proper working order. I have replaced the IPR, ICP, and HPOP as far as no oil pressure goes. The drive gear bolt on the HPOP was torqued to 95lbs per specs and mesh is correct as far as the gear goes. Also changed the IPR and ICP. Yet i still have no oil pressure going to the injectors making them fire. Fuel check showed clean fuel so no leakage from injectors needing to be resealed. If anyone could help guide me to the next possible solution id greatly appreciated it. The bus ran and drove before installing all these new parts just randomly died one day while idling in the driveway, now here I am tons of hours and money later.
New parts:
Glow Plugs
Glow plug relay/solenoid
Valve cover gaskets with new wiring
IPR
ICP
HPOP
Oil change (Rotella T 15w-30)
Oil Filter
Fuel Filter
Crank no start!
New parts:
Glow Plugs
IPR
ICP
HPOP
Oil Filter
Fuel Filter
