BusBiz
Does anyone have experience with this issue? The cruise control is not functional..
A fault code from the stop arm or 8-way roof safety lights on a 2014 Thomas Freightliner C2 Saf-T-Liner can make the cruise control inoperable.
The stop arm, 8-way lights, and other safety equipment are integrated into the bus's electrical system, often governed by a Bulkhead Module (BHM) or similar multiplex system. If this system detects a fault in the safety lighting (like a bad relay, short, or improper signal), it can trigger an active fault code that prevents the Engine Control Module (ECM) from engaging the cruise control for safety reasons.
Here is a breakdown of why this happens:
- Integrated Safety Systems: On Thomas C2 buses, the warning lights and stop arm are part of the Body Control Module logic. If the system thinks a stop arm is extended or if there is a malfunction in the 8-way warning system, the ECM will not allow cruise control to engage.
- Voltage/Ground Issues: A faulty stop arm relay or motor can cause voltage irregularities in the system. The cruise control system on Freightliners requires consistent voltage, and a, "short to ground" or blown fuse in related circuits can cause it to stop working.
- Safety Interlocks: The cruise control is designed to disengage if it receives a signal that the vehicle is in "stop mode." If a faulty, 8-way light switch or stop arm switch is sending a "falsely active" signal, the cruise control will not engage.
- Check the bulkhead module (BHM) for active codes.
- Inspect the stop arm relay and connections for corrosion or damage.
- Check for a blown fuse in the driver's side fuse/relay panel labeled "Cruise" or "Dash Switch Power".
