JenniferWillow
‘ELSEWHERE’ 1997 International 3400,T444e
Hi everyone,
I’m in a curious situation. I have a 1997 International 3400 T444e bus manufactured by Midbus. I’ve got BlueFire connected and a Nexiq USB link 3 that connects to the 1708 bus. I’m reading parameters, displaying telemetry on a custom dash, etc.. I thought everything was OK with my ECM but 2 weeks ago we were on a trip about 70 miles from home and the bus slowed to 20 mph on the freeway. I got off the expressway and took it to the first diesel shop I could find. They read codes (not sure what software) (5 total, 4 related) that indicated no communication between the ECM and the VPM, corrupt KAM memory and running on defaults. All the codes were inactive. The next morning we headed back and the bus stalled just after going through an intersection. We pulled over and started to arrange a tow with Coachnet. After about 15 minutes we tried starting it again and it started right up. We drove the rest of the way home with no problems.
So how is this curious? Sounds like any other problem right? Well first I checked the BlueFire app and there were no codes? I said Ok, maybe I need proprietary software to read the code? Maybe it’s BlueFire? I called a diesel mechanic to come out and on the first visit they didn’t have the right laptop with ServiceMaxx 1708. They came back a week later with the old laptop and it wouldn’t connect. They charged me nothing. Nice guys. So I ordered the Nexiq and setup ServiceMaxx on my Windows laptop and tried to connect to the bus. It connected immediately (just like BlueFire). So I’m happy until I try to read DTC codes….. nothing
summary:
BlueFire : no DTC codes, good telemetry, easy connection
DieselDoctor : can’t connect
ServiceMaxx 1708 : no codes, good telemetry, easy connection
I’m getting plenty of communication, lots of telemetry (oil pressure, water temp, etc), and I can see and plot damn near any value I can think of but NO DTC CODES. The bus clearly had a problem that should have thrown a few codes but nothing. All the codes I got from the first diesel shop were acquired by the press diagnostic button and turn on key procedure (counting light blinks) which bypasses the VPM. I’m assuming that I’ve got some wiring problem between VPM and the ECM, or more likely a bad VPM, ECM or both. But why am I getting all the telemetry but not the codes?
Best Possibility: The shop in Ventura cleared the codes when they manually read them. There have been no DTC codes thrown since (despite stalling out for 15 minutes on the side of the road). Likelihood ~ 10 percent (actually less)
Worst possibility: The ECM, VPM and the harness between them needs to be replaced.
What’s curious about this is that as far as BlueFire and ServiceMaxx are concerned there are no DTC codes thrown. The bus is running fine but it’s not. The codes read “manually” (I.e light blinks) come from the ECM directly so I’m inclined to trust them.
Question: Has anyone been able to connect and get telemetry (fuel consumption, water temperature, etc)on the J1708 bus but not been able to read DTC codes? Has anyone been able to connect, get telemetry but not DTC? on any 1990’s bus.`
So do I have to spend several thousand to update/replace the ECM, VPM so I can read codes? I know the bus bus won’t last 6 months on the road if nobody can read the codes. If nikitis sees this I’m in almost exactly your situation the night before you took yours to the International dealer. I’m headed in to the local dealership tomorrow morning. I’m hoping, **** I don’t know what I’m hoping for. Maybe this, tell me to replace / rebuild both the ECM and the VPM for the absolute minimum cost (the diagnosis not the cost of the hardware).
Thanks for reading. I hope someone knows something about systems where you can’t read DTC codes and how to fix them.
summary:
