Curtains
Danjo-SKO
Sep 22, 2018
2,831
I’m getting there! This is definitely getting a little further out in the calendar. I bought some fabric, so it’s sort of set in motion.
I need to design curtains. I might not be sewing, but I’ll be making the template, doing the cutting, and doing the layout
So, what do I do? :)
A couple questions that I have are;
How wide? One window, 2? It’s a 5 window bus if that matters.
Rod, wire, paracord?
Supported at the bottom too?
Did I ask previously? I can’t remember.
Thanks!
Part of the answer can only be provided once you determine your plan for the curtains. For example, if you want them for insulation, then you would want the curtains to be as tight fitting as possible ... so individualcurtains for each window.
