I am an unapologetic tool geek. I enjoy using high quality tools. And I'm big enough to admit that I probably have an underlying tool problem.
[Rant]
If your kids are interested in music, the absolute worst thing you can do is give them a crappy 'beginners' instrument to play. They generally suck and they are often very hard to actually play because they are made so poorly. Get them a good quality used instrument. If junior decides they are not the next David Gilmore, then you can sell a good used instrument. You can't really get any value from a crappy instrument.
[End Rant]
Tools are like this too. And shortly I'm looking at making a ton of brackets and frames to hold grey and black water tanks, battery trays, propane trays, and a few bumper-mounted accessories. I spend a lot of time cutting and then grinding bar stock to size, and even then it never fits as well as I want it to.
Say hello to my new friend! This wasn't cheap at $500, and is actually the bottom model of the Evolution line, but everything above the pivot hinge is the same as the fancier tools. It is more than enough saw for mere mortals. It cuts cleanly, squarely, and is highly repeatable with good measurement technique. I am so freaking pumped.
Some test cuts and a DoppelFrankenWeber cart I'm making on an old gas grill base.... ;>)
[Rant]
[End Rant]
