osg828
I have a 2007 Thomas c-2 Freightliner I bought with Check Transmission light on.The bus did move with no problem when I got it,then it sat for a while and I had to floor it to get it to move,reverse was fine.Now it won't move either way.I read all the stuff about brakes being locked up,rusted,and so-forth.I jacked it up ,took back wheels off,put it in gear,and everything moved fine.Put it back together and still have same problem.Note this does have Allison Transmission in it,so debating to get a used tranny for it or am I missing something,I bought this for storage,but would like to move if I have to.Any help would be great,also having trouble finding diagnostic port,I bought a scanner that should work. Thanks
also already changed fluid and spin on filter,nothing was in the pan.
