1000 AND 2000 PRODUCT FAMILIES TROUBLESHOOTING MANUAL—ALLISON 4th GENERATION CONTROLS
Limp Home Test
With the ignition in the OFF position (engine not running), the selector in N (Neutral), and the parking
brake set, remove the 80-way connector at the TCM.
It will be necessary to provide battery power at pin 41 of the 80-way connector in order to energize the
neutral start relay. This can be accomplished by using a jumper wire between pin 10 and 41 at the 80-way
connector.
When the engine is restarted, the transmission will default to a “limp home” capability. In this state,
PCS1 (de-energized) allows C3 clutch to be applied. If the selector valve is moved to the reverse range
position, main pressure will be routed to C5 clutch, allowing reverse operation. If the selector valve is
moved to the drive range position, main pressure will be routed to C1 clutch, allowing third range
operation.
This allows a technician to use “limp home” capability to determine if a hydraulic or an
electrical problem exists. If reverse and third ranges are available in “limp home,” an electrical failure
may be indicated. If only one of the two ranges or neither was obtainable, this may indicate an internal
hydraulic failure (failed clutch, stuck valve, or solenoid failure).
The clutches that could possibly have an
indicated failure in “limp home” are C1, C3, and C5.
