slowly knocking off items on my todo list and the heater is finally back installed.
i re- assembled the heater, per the prior pics.... and screwed up. i had missed bolting down that sensor earlier..... and now the bolts at the end of assembly didnt match out. something was wrong.
so i took a couple of hours and disassembled the heater again. i put the wrong bolts in the combustion chamber on assemble #1. at the end, i had 4 bolts left over and 1 was longer than the other 3.....so, i realized i had the combustion bolts and not the case bolts at the end.
so apart the heater came and i fixed my errors. right bolts, right spot. temp sensor secured. case fits right with the bolts at the end.
the heater did drop back into place pretty easily. i was expecting a fight. the wiring hooked back up and i ran a test cycle.
i took a video of the fuel pump output. its similar to the first video, so maybe the fuel pump wasnt a problem at all. 1 drip per click.
but once the fuel line was hooked up, she started up and lit on about the 3rd click of the pump.
so all happy now..... heater works... just in time for this cold patch.
