cadillackid
parallel flow is how I set the system up.. the heaters all have an in / out so you can pipe them in however you like.. but the bus design is typically either parallel or series..
in a series system, the hot coolant leaves the engine, goes in one heater core.. and out the other side.. then goes into the next one in the line, and out.. once the coolant goes through the last heater core it makes the lon g return trip back to the engone to be heated again.. that last heater core under heavy load conditions (all the bus heaters on high and engine idling).. the l;ast heater wont be very hot..
blue bird tends to build all their busses in this manner..
a parallel flow system is one where you have 2 main trunk lines.. so coolant comes out of the engine and flows down the main line to to the end..
each heater has a 'T' connection into the main supply line and then the other side of the heater core, 'T's into the return line.
the last heater often has smaller lines or has a restrictor device in it so to keep a pressure differential going between supply and return, facilitating flow..
in high load.. engine idle situations.. all of the heaters tend to blow a little less hot air rather than having any of them blow cold..
so now in a series system is you close a valve to the engine.. you lose all flow through all the heaters.. its in / out and you cut off the main supply...
in a parallel system if you close one valve.. all the flow stops also.. EXCEPT you can put in a pump.. I put mine in the end at the rear heater.. the flow reverses through the heater cores as the return line now becomes the supply.. you pipe in your diesel coolant heater in parallel.. or you can send all the coolant from the main supply line into it in series.. if you clkose the engine heater valve (just one not 2). and you turn your coolant heater on.. its pump circulates coolant within your closed-loop of the inside of the bus.. it pushes coolant into the trunk line.. creates a pressure differential and that flows coolant through the bus heater cores...
if you open the engine heater valve now some coolant is going to flow intop the bus engine.. (it doesnt take a lot of flow to warm the engine).. and coolant still flows through the heater cores (yes you use a pretty strong pump)...
that said i tested mine.. so overnight it was minus 12f, I did a cold start of my engine (it doesnt have glow plugs).. and it started hard!!..
I left it sit all day.. the highest it got today was minus 5.and has been windy.. so I started the coolant heater with the engine valves open.. and left it run for about an hour.. I came back to the bus and it started like summertime...
tomorrow morning is supposed to be minus 20f, I wont even try to start it without first preheating.. so ill preheat for at least an hour or more before trying to start.. its only 830 at night and its already down to minus 12 here..
because its so cold.. I will drive with the coolant heater on.. and of course all SEVEN bus heaters on high.. once I get to the freeway im guessing Ill be able to shut off the coolant heater..
