Ray_WA
- Joined
- Nov 6, 2008
- Posts
- 193
What have they done to that poor bus?
-Ray
-Ray
the_experience03 said:I honestly wouldn't mind undertaking a hot rod bus project. I just don't care for a lot of stuff on that one. The chopped look is cool, but they should have taken material out from below the windows for instance. Also, a FWD Eldo frame? If you're going to use an Eldo frame you might as well keep the 500 cubic inch monster that was supposed to be there, not that a 430ci blown Olds can't get up and move.
Jarlaxle said:The Olds "430" is probably no more and no less than the 425 that many Toronados were built with. It's better for a blower than a 455 due to the forged steel crank (455's had cast cranks).
Jarlaxle said:Ye gods...a 403 with a blower is a hand grenade. 403 blocks are Oldsmobile's weakest, with gray iron crankshafts, hollow main bearing webs, and thin cylinder walls.
