mrpincher
Below are three pieces of equipment that I’m considering for a solar power system in my bus.
My real power needs are in the 4500 Whr range. I want a bunch of head room above the 4500 range so I can run a space heater in the winter and lots of fans, even off-set some time on my generator in the heat of summer. I’ve been running a killawatt for about a year.
No solar panels planned at this time(have room for 6). Will be charging the battery bank from shore power and generator until I buy panels in late spring 2020.
Am concerned with mismatched components and am wondering how long it will take for the 24v 400Ah battery bank to charge to up to 90% with this 80A charger.
Here’s the list: 1 each - 2400w Pure Sine Wave Power Inverter; 80A MPPT Solar Charger; DC 24V; AC Output 110V 120V; 60A Utility Charger; 60HZ.
https://www.amazon.com/gp/product/B078746PG3?pf_rd_p=ab873d20-a0ca-439b-ac45-cd78f07a84d8&pf_rd_r=R9CMVVP1NGGWHH21K9VF
2each- BMS - Smart 7S to 20S Bluetooth 300A lithium Li-ion Lipo LTO LiFePO4 Battery BMS Protection Board 24v
Charging current: 50A
Balance current: 100MA
Wiring method: same port
Size: length 14CM width 7CM thickness 1.7CM
Single cell voltage: detection range 1V-4.6V, accuracy less than 5Mv
Overcharged and paid: protected
Working voltage: 15~80V
Short circuit protection: short circuit protection current can be set
Bluetooth connection: for Android android hand sail
Applicable battery: 7-16 string Li-ion Battery; 8-16 string Lifepo4 Battery;8-16S Titanium lithium
Coulomb counter: accurate calculation based on current versus time
Battery remaining capacity, error range is less than 5%
Power consumption: 3MA at work / 1.5MA during standby
2 - 24v 400AH batteries - CATL NEW 3.2V200AH LIFEPO4 Product Lithium iron phosphate cell. 16 PCS CATL LIFEPO4 battery 3.2v200AH 2019 new Rechargeable Batteries cell for 24V200AH for RV SOLAR EV Marine
Product Specification Product Name: Lithium iron phosphate cell
Shell Material:Aluminium
Rated capacity:200Ah
Minimum capacity:199Ah
Internal impedance:0.1~0.5mΩ
Nominal voltage:3.2V Dimensions(L*W*H):174*54*207mm Weight:4.0±0.10kg
Recommend Constant Current:2000A(1C)
End-of-Discharge Voltage:2.5V
Recommend Constant Current:100A(0.5C)
Charge Voltage:3.65V
Maximum Pulse Discharging Current:600A, Charge Voltage:3.65V, Max Continuous Discharge Current:200A(1C), Cycle life (80%DOD):4000 cycles, Charging Temperature:-5~60°C, Discharging Temperature:-30~60°C
Thanks for looking -Mike
