Doghouse gasket seal
milkmania
May 6, 2015
2,447
Oklahoma aka "God's blind spot"
Didn't know which forum to use, so I dropped it in here.
Where can I get a doghouse gasket seal?
I can feel the fan blowing cold air into the bus when it's running and there's quite a bit of seal torn away.
Won't work for mine, it's a rubber neoprene gasket that compresses down when I buckle the straps.
Similar to this
That is a fairly common weather stripping. Have you checked your local auto parts store?
I'm having trouble visualizing where the doghouse gasket is. Can anyone clarify?
Look at Mcmaster Carr that is where I ordered mine from. Also get the 3M black gasket adhesive if you intend on cutting and glueing corners.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Aaah. I was envisioning a conventional style bus, not a flat nose. Guess the doghouse isn't an issue if you have a dog nose.
