Anyone had a RV style freezing AC issue?
Unit is a dometic brisk air II, with ceiling controls, non ducted. I was down in waterton AB area this weekend and it would freeze up in 10-20 minutes. I had to keep cycling off the compressor and running the fan to defrost it and there would be a giant gush of water from the drainage channel on the roof. Pain in the butt.
Online says either its humid or I was running the fan on low, neither which are true. I was running the unit on full blast and it was dry as f*@$ down there.
I took the cover off today and the condenser is not dirty at all, nor is anything blocking airflow. The baffle that separates warm air going into the unit and the chilled air exiting the unit is well sealed with no leaks.
I know the photo looks like styrofoam but thats an ice block!
