Sumblkguy7
Hi all,
I'm wrapping up the main door of my 2010 Thomas and I ran into a bit of a snag with the RV door handle. The door is made of steel sheets with 1.5" square tube.
The issue seems that I didn't account for the RV market being very specific about the 1.5" max thickness and I'm a hair short (roughly 0.20"/5mm) of the interior mechanism latch arm from pulling the latch bolt.
The deadbolt works fine but I can only feel a point 1 and 2 (from the picture) barely touch and it's not enough to pull the latch bolt at all. Priced out some machine work for the modifying the parts but both quotes sit over $100 for a $20 latch. I want to keep the RV handle aesthetic and remaking the door in 1.25" square tube seems like overkill but I can't seem to see the simple solution here. Anything obvious I'm missing or some thicker RV door handle type?
Thanks!
Thanks!
