Fuel level sensor
Since we bought Dory it had a broken fuel level sensor.
Last week I did some measurement to confirm it being the sensor and not the gauge or wiring.
Confirmed the range as being 33.5 ohm to 240 ohm.
Red is gauge wire, black is ground, blue is low fuel light to ground.
The sensor is made by intellitech. The partnumber does not show up and I have a feeling it was made specifically for this bus.
Coming back from our last trip I decided to dig into it. Cleaned up the tank around the the sender and removed the 5 screws . Was able to pull the sender out but could not remove it.. well there is the access panel to the front of the engine ..indeed that did the trick.
Took the sender apart.. two yellow copper plates separated 1/16 of an inch. Must be a capacitive sensor. Dug a bit into the potting to see if I could the electronics out but gave up.
Decided to modify some fuel sender I liberated from a Volvo big truck that was at the scrap yard .
Range good, unfortunately a round tank , mine is square, and the sender is to long..
The Volvo sender also is a two wire. I need a two wire and a low fuel wire, so mods are required.
Coming back on the intellitech..so this sender gets the power thru the gauge wire, similar to 4-20ma circuits. Then it activates a transistor / fet to pull the third wire to the low fuel light down to ground. That is incase the capacitance is low enough.. the yellow copper was dirty, cleaned it and tried again without luck. I will did it out later or see if I can find another one and exchange the sensor part.
