DragginVR
We got a British Double Decker Bus last year and it was in dire need of exterior refurb and dash redux. We were originally going to fix this up to use as a winery-tasting tour bus. As explicitly unique as possible, but we came to realize that Alcohol without food is not a good insurance liability to have. So we never got to the interior, but decided to put it up for sale instead. I thought I would chime in for the folks out there that have ever thought about working on double decker buses. For starters, you can import a bus for around $14-18K depending on where you live, plus the cost of the bus, which ranges from $4000-15,000. The only real problem is the height of the bus and not knowing what you are getting, but if you play your cards right, you can buy right. The height issue is anything over 13.5ft tall is not going to be tagged unless you apply for special permits in some states, if at all. This usually results in an "opentop" bus where they chop off the roof to comply with US Federal road requirements. You still have to avoid country roads and residential streets or travel with care. US highways and interstates are rated over 13.5ft tall. I wanted to start out with the original bus pics and a quick progression to where it is now. I have a video on youtube as well: http://www.youtube.com/watch?feature=pl ... gDb_x-wumM
