slipperysam
- Joined
- Aug 25, 2020
- Posts
- 23
I found my "perfect" bus! But of course, it's not quite perfect. This is a 2000 Bluebird transit-style bus equipped with a Cummins ISC 8.3, and a HUSS DPF. I've done some digging on DPF in this forum, but couldn't find what I was looking for, so if someone wants to link me a thread I'm happy to read existing content.
Main question: I imagine since it's from 2000, this DPF was added after the fact (the bus is from CA). I know we should prefer pre-2004-emissions buses, which would exclude the ISC, but I'm ready to just accept that the rest of my constraints won't be met with the available buses from that era. However, I'm curious if this DPF system should be thought of as another necessary evil to live with, or if I should avoid it at all costs?
And if you think it should be deleted, my next question is: how common are deletes, really? And if I never register the vehicle in CA, there really shouldn't be a way for me to get in trouble for that right?
Secondary question: I learned that "the rear axle housing has cracks in it and needs to be repaired or replaced." Any ideas what this will cost? I plan to get some quotes near me but I'm going to ask for a deduction in price and want to be reasonable. (I'm also working on the assumption that this fix can be put off until the bus makes the 1770mi journey to its new home - yell at me if this is a bad assumption please).
Also, as a total newbie with this stuff, If I did replace instead of repair this rear axle housing, can I also use this as an opportunity for rear axle changes? E.g. change the rear end ratio? Or swap in a 10sp manual?
Thanks for any help! Excited to get this bus and be a more active member on here! :Thanx:
