Walked out to do some work around the house and noticed the headlights were on. Been sitting for a couple days after a trip and I know they were off since we got back. Hadn’t been on long enough to drain the battery since it started right up. Checked and the tail lights are on too. Pulled the DRL fuse and everything turns off. Pulled the DRL relay and tested with a 12v battery and continuity is what it should be.
Any other ideas where I might find this latest ghost in the machine?
It’s a 1999 bluebird conventional. I had electrical issues a year ago (wouldn’t start - seemed some safety engaged that I could never find) which I solved with a temp contact push button starter switch directly wired between the battery and the starter.
