ewo1
SR. MEMBER - 99 Amtran RE DT466E HT 250HP-Md3060
So it seams that Murphy from Murph'ys law is paying me a visit...
Took my 9906 bus out for a ride, been sitting for 7 months, and not 5 minutes into the ride my "WARN ENGINE" light came on.
BEEb2 you are not alone!
LOL....
I hooked up Servicemaxx and started looking at the numbers.
coolant temp while testing was around 180 degrees
idle oil pressure at 26 psi but goes upto 50 psi no problem
Engine warn light ON
ICP desired 725 psi
IPR ctrl 16.45%
ICP pressure 725 psi
Engine Warn Light OFF
ICP desired 435 psi
ICP pressure 1342
Oil and filter, delco 15w40, changed 14 months ago, only drove the bus 1700 miles so oil is still relatively new.
Engine has around 210K miles, runs strong! No oil or coolant leaks!
Original IPR and ICP in bus, have not replaced.
When you start the bus, engine cold, she runs and shift fine but within 2 miles warn engine lite comes on and bus looses all power, limp mode. Barely 25 mph, engine surges when this happens.
with engine hot, clear DTC in S/M and within 10 seconds it comes back.
Ran KOEO test, injector test, each one failed when check engine light on, does not stall just runs rough. no blowby.
what am I thinking for repairs...
change oil and filter - see if it improves.
Torn between ICP or IPR, I think I might go with ICP as it costs less. If it turns out to be the IPR then I just save the old ICP for any future emergency, mine or a fellow stranded skoolie?
I have read the HPOP start to go downhill after around 200K miles. My idle oil pressure is steady at 25 psi and goes up quickly to 50 psi while driving and it says there.
I don't remember if I ever changed the fuel filter, or did the fuel gel from sitting over the winter... I don't think it is related but since I am in the engine I might just go ahead and change the fuel filter.
fingers crossed it not a failing HPOP!
LOL....
ICP desired 725 psi
IPR ctrl 16.45%
ICP desired 435 psi
ICP pressure 1342
