Hey everyone, just drove this truck home a couple weeks ago. About a 15 minute drive, ran it for an hour or so prior to that drive. When I got it home it sat for a few days. I changed the glass water separator as it had a bit of gunk in it and forgot to prefill it. I started the truck, ran great for a 5 minutes idling then died when air got to the pump. Now I can’t seem to get it to prime at all, I pressurized the driver side tank and got fuel geyser’ing out of the inlet line to the fuel lift pump/pump where I have the red arrow. Not that When I pressurized it, instead of the clear tube on the bleeder valve (blue arrow) I had the bleeder valve in. I connected all the lines again but I can’t get fuel past the lift pump, which I believe it needs to go past it to get to that bleeder. The hand primer pump isnt that great and wouldnt or do much, got a new one and it doesn’t do much good either even after 100 pumps. I did have to replace the check ball also as it was all mangled, strainer was replaced but pretty clean. Fuel filter replaced and pre filled. It’ll run on a shot of ether otherwise. Fuel grommets changed as needed. It almost seems like the fuel pump is completely blocking fuel getting past it? I don’t know if that’s normal for these. At a loss, been out in the rain trying to get it going. any help/ideas is really appreciated
